1994 new water pump makes service engine light come on?
smileslynn
05-14-2010, 04:19 PM
changed water pump hooked everything up double checked it all with the repair manual also had a friend look at it to make sure everything went together correctly but i turned the key and the service engine light has now come on and i have NEVER had this light on before.. any advice?:crying: kinda scared to move the car:banghead: and im a single mom i need my car. ty for any advice yall can give me.
Blt2Lst
05-14-2010, 05:05 PM
If no wires or vacuum lines were disconnected or broken upon assembly, you will have to scan the car for codes to see what's up.
Was the coolant topped off, a low coolant level can trigger a CEL
You can drive the car with a CEL on, just make sure it is not leaking coolant.
:2cents:
Blue Bowtie
05-15-2010, 02:29 PM
Make sure the CTS is connected properly.
j cAT
05-15-2010, 07:02 PM
most when messing this job up do not properly reconnect the air pump correctly...recheck the air pump hoses /vacuum lines/electrical
