trooper shudder jumping
metalhead608
05-10-2010, 08:41 PM
from a stop sometimes the trooper will surge shudder jump whatever a few times then take off...? its a 2001. so i'm thinking plugs,battery,throttlebody cleaning, fuel filter.
anything else i should look for? or anything else i should get for it?
i dont know anything about these engines. what is the torque for the plugs? thanks for your input. josh.
fourwd1
05-13-2010, 01:47 PM
First thing would be to take it and have it checked for Error Codes.
Auto or manual trans?
metalhead608
05-14-2010, 10:34 PM
auto trans, can this be checked with the OB port? or a dealer thing?
fourwd1
05-17-2010, 01:25 PM
Yes, you need an ODD-II scanner. Any parts store will do it for free around here.
Some codes are Isuzu specific, so some scanners will just show the number but no description. If so post the code here.
The reason I asked if it was an auto is because there's a switch connected to the shifter linkage that can go bad and cause a number of driveability issues.
metalhead608
03-03-2011, 05:30 PM
in the summer i did the plugs boots battery fuel and air filter. no change.
fluid is full in the trans. where and how do i check the switch? could it be the cv joints? or the driveshaft?
fourwd1
03-04-2011, 09:05 PM
Have you checked for error codes yet? If any have been stored it help you solve your problem.
metalhead608
03-04-2011, 09:10 PM
No codes at all, thinking drive shaft?
fourwd1
03-11-2011, 10:13 PM
The transmission mode switch is a common problem. It gets worn and dirty and does not send the ECM the proper info (what gear is selected). It can cause all kinds of problems.
If you Search the forum you should find several threads on it. I can't remember if mine caused any error codes when it went bad.
bbjinad3
03-11-2011, 10:35 PM
I've created a website using a template. In all other aspects it is working fine, except that as you click through the menu choices.
