Emergency help needed...
ci5ic
05-02-2003, 05:54 PM
Where the hell is the transmission fluid fill-bolt at?!
I can't find it for the life of me, and I NEED to change my tranny fluid today... Please help...
Is it under the starter or something?!
crxlvr
05-02-2003, 06:10 PM
on my crx, i had to remove the passanger side wheel well plastic to access it. after you remove that, you will see the knob you have to turn to release it.
ci5ic
05-02-2003, 06:12 PM
crap.
amy@af
05-02-2003, 06:14 PM
http://www.binghamtonlife.com/manual/2gsm/images/91-13-3.jpg
jeef
05-02-2003, 06:15 PM
what he ^ said.... you can unscrew it with a 3/4" rachet and extension...
damn you ami you messed up my little "^" in my post :D
amy@af
05-02-2003, 06:16 PM
that came from http://www.binghamtonlife.com/manual/manual.htm
you can DL the whole helm's there
*2nd time today i've used images from there to help somebody ;)*
T-Mo
05-02-2003, 07:31 PM
Are there any sites for the Hatch????
crxlvr
05-02-2003, 07:45 PM
anyt sites for an auto b16a?
kris
05-02-2003, 08:24 PM
Dont forget the long tube.
amy@af
05-02-2003, 09:06 PM
nope, don't know of any. it's not exactly needed. the civic and crx have the same engines (and tranny) :D
ev0lution7
05-02-2003, 10:57 PM
OUCH its NOT a 3/4 what the heck slinkies are ya thinking is a FOREIGN CAR use a MM socket not a SAE socket its a 17mm i think and becarefull my buddie stripped his cuz he USED a 3/4's and we had to remove the axle to get the fluid in the car and dont use a funnel do it right and buy a BOTTLE mounted hand pump they are like $5 at kragen and WELL worth it also make sure u clean the area really good and BUY HONDA MTF it is the best stuff for your tranny your tranny will thank you 10k miles down the road
FourthGenHatch
05-02-2003, 11:22 PM
The actuall fill hole is under the starter, you must remove the starter to fill up the tranny.
jeef
05-03-2003, 12:07 AM
no no no... if my memory serves me correct its not like a hex headed bolt... you actually just insert the rachet direclty into the head of the bolt... and why did you have to remove the axle??????
Civic Rush
05-03-2003, 09:00 AM
That is exactly what it is.....and you have to have is a 3/8 rachet into the bolt...:D
AlwaysMovin
05-03-2003, 09:48 AM
crxlvr: anyt sites for an auto b16a?
Check out http://tech.hybridgarage.com/tech/, on the page look for
88-91 Civic/CRX Service Manual (PDF) and 88-91 Civic/CRX VTEC Supplement (PDF).
kris
05-03-2003, 12:21 PM
There is nothing wrong with a funnel and a long ass tube either.
ci5ic
05-03-2003, 01:21 PM
Yeah, I finally found it using the Helms manual for the CRX, but that bitch is on there tight. I couldn't get it off for the life of me using an open-ended wrench, and I couldn't fit a ratchet in there, so I gave up for now. Which is okay, I bought a funnel with a long flexible acordian-type tube, but realized that the diameter of the tube end is too large for the fill hole, so I'll have to figure out a way to get at that bolt...
And yes, I got some Honda MTF for it.
crxlvr
05-03-2003, 04:51 PM
thanks i have those, but they arent for the automatic version of the b16a.
the auto b16a was only in the integra rsi and xsi from other countries, never in a civic/crx.
ev0lution7
05-03-2003, 05:47 PM
guys the 3/8 ratchet end bolt is for the DRAIN PLUG (duh) and we had to remove the axle cuz we couldnt get the fill plug off look at the underside of ur car u will see and NO u dont have to remove the starter to fill the tranny not even all data says that
