Crx Si cluster in DX
2001MGGT
05-02-2003, 08:36 AM
I picked up an 89 Si cluster to replace the one in my 88 DX with a broken fuel gauge needle. I plugged the new one up and I'm getting some odd results. The check engine light comes on, the tach does not work, the fuel and temp gauges go crazy.. moving up and down. The only thing that seems to work are the turn signal blinkers... go figure. I think I remember someone saying you had to reverse a pair of wires in the harness, but I'm not sure. Anyone got any ideas on this?
Civic Rush
05-02-2003, 09:02 AM
first off are you replacing it in a hatch or sedan
2001MGGT
05-02-2003, 09:29 AM
It's an 88 Crx hatchback with an 89 Crx Si hatchback cluster placed into it.
Civic Rush
05-02-2003, 10:02 AM
hmmmmmmmmm should just be a plug and play....have you compared the 2 yet...like put them side to side to make sure that they are identical.....
91civicDXdude
05-02-2003, 10:06 AM
that sounds exactly like what happens when u try to put an 88-89 cluster into a 90-91 car...........well and the lights are mixed up like the turn signal light will be the seatbelt light or something crazy like that.
Civic Rush
05-02-2003, 10:07 AM
I don't know about the 90-91 I know it does that when your tryin to do it from like a CRX into a Civic or the other way around..:confused:
2001MGGT
05-02-2003, 02:42 PM
The two are a little different, the Si cluster temp and fuel gagues are farther apart with shorter needles. There is also some kind of light between these two gauges that wasn't on my original cluster. The speedometer appears a little smaller to compensate for the additional space between the fuel and temp.
