Passanger Door Handles (Power Locks)
cscott784
04-30-2003, 12:25 PM
Hey all. I saw a car on the forum with rear passinger door handles on both driverside and passenger side front doors. The car must have power locks to do so. I wanted to buy a powerlock setup on ebay (http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2412761955&category=33723) but would it be compatable with my car (90 hb manual everything). Also, is that just a cheap alternative to shaved door handles? or is it pretty cool?
Thanks
Scott
Cfmotorsports
04-30-2003, 12:39 PM
i have those door locks on my car and they work very good, i do not have the handles but i have thought about getting them. maby later i will do that. but you do have to have an alarm with door lock in itso that you can operate with your keyless i have pics of the install if you need any help just let me know i know sombody on here had a how to fo the 88-89 but it will not work the same on the 90-91 becuse of the seatbelts its a little tight to get everything to fit. took me a couple of trys to get everything to work and clear the door panel.
aces1980
04-30-2003, 12:42 PM
Thanks
Scott
Hey yeah that will work. All you would need now is a keyless entry module with the controls. I just did this mod to my car, except i got the alarm system. there is a how to here somewhere let me look for it and i'll post it
cscott784
04-30-2003, 12:49 PM
nice! HEy cfm. Can you send me the tutorial that you used for your car. I have a 90hb as well. I would like to order these today, so a.s.a.p would be great! I also am doing 2 tutorials today. One of them is the alarm and another is installing a thermostat. If anyone needs any help with an alarm just holla.
Thanks
Scott
ci5ic
04-30-2003, 01:17 PM
I've got the rear-door handles from a sedan in my hatchback with the keyless entry. It kicks SO much ass. For one, you never have to use a key to unlock your door, and since my handles were painted, I was always worried about scratching the paint with the key. Second, you can remove the lock push-rod so that thieves can't use a slim-jim to open the door. Third, obviously thieves also can't punch your lock to open the door. Fourth, it looks super clean, and it's a pretty cheap mod, I got my handles for $40 total from the junkyard.
Just go to a local car-audio shop and pic up the actuators, they're like $15 bucks a piece. Then install them and hook them up to an alarm system with keyless entry. Bang.
aces1980
04-30-2003, 01:39 PM
"Second, you can remove the lock push-rod so that thieves can't use a slim-jim to open the door. Third, obviously thieves also can't punch your lock to open the door."
What if u locked yourself out. How would you be able to get in? Cause i have been thinking about changing the door handles but kinda scared.
GTA
04-30-2003, 01:48 PM
climb through the hatch.
ci5ic
04-30-2003, 01:50 PM
For hatch-backs and CRX's, you can still use your key in the hatch and crawl in if your battery dies or whatever...
For sedans, I'm not sure... It would be possible to hook up some sort of hidden exterior trigger so that you could use a 9-volt battery to get in or something...
cscott784
04-30-2003, 02:05 PM
How long does it take to install?
Scott
ci5ic
04-30-2003, 02:17 PM
For the actuators, all you have to do is remove your door panels, drill 2 holes and screw the actuators in. Then attach the actuator rods to the lock-rods, and that's it. Then you just have to run the wires through the door to the relays and the alarm system... Personally, I just installed the actuators and let the local car-audio shop install the alarm and relays... if you already have an alarm, just take it in and have them wire up the relays and actuators...
Only took me about 4 hours to remove the door panels, install the actuators, and re-install the door panels.
FourthGenHatch
05-01-2003, 11:21 AM
I did Keyless and the Sedan Rear Door Handles, here are my How-Tos...
http://www.fourthgenhatch.com/keylessentry.html
http://www.fourthgenhatch.com/sedanhandles.html
FourthGenHatch
05-01-2003, 11:25 AM
It would be better to install that switch in the trunk, you can still open your trunk with the key, put in some kind of small switch or a cable that would fold down the seats or something like that, incase shit happen!
