95 Maxima coolant leak
randyjaneway
04-03-2010, 04:21 PM
Coolant leaks out as soon as it is poured in; it runs down the front of the block between the power steering pump and crank pulley. At first I thought it must be the water pump, but after looking at where the water pump is located (on the opposite side of the crank pulley as the power steering pump) I wonder if it could be the water pump. Does this sound like the water pump is leaking, or should I be looking for something else, and if so, what?
Nahkapohjola
04-04-2010, 03:10 AM
Water pump. Its the only coolant issue wearing down by the mile. Tend to go in any engine 'after 100k' miles... (rarely head gasket).
Dont drive (long trips = hot engine) before u get coolant leakages in ctrl, risk is engine heads warp and gasket start leaking.
