rear-end grind
BIGRODROSIN
03-30-2010, 06:30 PM
96 grand cherokee, 5.2l, my rear-end grinds, gets louder with speed, does not change pitch or amount with acceleration or deceleration(like a gear issue) new bearings both sides and mechanic says 800 bucks to fix, any ideas??
hundahunta
04-01-2010, 04:07 AM
diff side bearings or axle bearings
BIGRODROSIN
04-29-2010, 04:21 PM
i replaced the outer wheel bearings, closest to the wheel, when i did that i looked at the ring gear teeth and they didnt appear worn. doesnt mean they're not
bub48161
06-01-2010, 11:26 PM
id say rear pinion gear i just had a 96 do the same thing and it was the pinion gear where the driveshaft hooks on at. put a new gear and seal on it its like new
mastertech1964
06-18-2010, 05:15 PM
sounds like the differntial side bearings are out which was a pretty common problem with these rigs particularly if it has the aluminum housed dana 44 the only solution is a bearing replacment and make sure the side bearing preload is set properly
