Bleeding rear disc brakes
qwertydog
03-30-2010, 06:19 PM
I have just replaced both rear calipers and tried bleeding them the usual way with a vacuum pump. However, the brake pedal is very spongy and on the first push it goes to the floor. Is there a better technique or method ? I have never had a problem with the vacuum method before.
Thanks for any suggestions.
shorod
03-30-2010, 09:29 PM
I had a similar issue in my 2004 Mountaineer, used the MityVac and bled until there was no apparent air in the system. The pedal still didn't feel right afterwards. I then purchased the brake bleeder kit from Harbor Freight (http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92924) when it was on sale for $19.99 and tried it out. It worked GREAT, I now have a firm pedal and good brakes.
The other option would be to install a set of Speed Bleeders and do a one person bleed, or use another person to perform a 2-person bleeding. Either of these methods would likely give similar results to the Harbor Freight system in the event you do not have a large air compressor.
-Rod
-Rod
qwertydog
03-31-2010, 06:49 PM
Thanks Shorod,
I used the "two person" method and now the pedal is rock solid. Perfect !
I guess the mini vac did not have enough pull to suck out all the air, so pumping the pedal did the job. Thanks for your advice.
shorod
03-31-2010, 08:59 PM
Glad to hear you have a safe pedal again. Thank you for the follow-up, and congratulations!
-Rod
-Rod
