2003 problems
krb5000
03-28-2010, 01:55 PM
Hi guys, first time on here. I just bought a 2003 with the 4.3 and crew cab. Is the blend door hooked to vaccum at all ? I ask because when I go up a hill cold air blows out of my dash vents and going down or level heat blows out the defrost vents. All this with the heater and fan shut off. I know you lose vaccum going up hill and this is why I am asking. Thanks
MT-2500
03-28-2010, 04:38 PM
Make sure it is getting good full engine vacuumed to it.
Unless it is leaking vacuum bad it should hold vacuum in vacuum ball
/ tank and check valve going up hill under load.
Hook a hand held vacuum pump to blend door actuator and see if it is leaking.
Post back what you find.
krb5000
03-28-2010, 04:44 PM
Thanks, So you are saying that there is a hose going to the actuator?
MT-2500
03-29-2010, 09:16 AM
Make and model and auto heater/ac or regular?
If acting up on a pull your are losing vacuum some place.
Have you checked the vacuum to it?
krb5000
03-29-2010, 03:36 PM
Truck is a 2003 s-10 crew cab with 4.3 I think it is just the standard heating control. Hav'nt checked anything other than I did check the heater sitting still and it seems to change from dash vents to defrost ok but when on the floor it does'nt seem to put out much.
MT-2500
03-29-2010, 03:48 PM
Check and confirm good engine vacuum to heater and heater controls.
Let us know how it goes.
krb5000
03-29-2010, 04:11 PM
I will this weekend, and thank you for all your help, Keith
