Door Locks
phill2942
04-15-2003, 08:45 PM
My '89 735i will not unlock drivers' door when using the key. Any suggestions?
jay76silver
04-17-2003, 08:04 PM
I have same problem, if U get the answer let me know.
phill2942
04-30-2003, 12:33 AM
LOCKING PROBLEM WAS DIAGNOSED AS BROKEN BRACKET ON DRIVERS HANDLE. ALLOWED ACTUATOR TO FALL DOWN IN DOOR AND ALSO HAMPERED WINDOW MOVEMENT. REPLACED WITH USED HANDLE FROM SALVAGE ( DEALER COST $300 +, HAVE TO BUY W/ CYLINDER & REKEY ALL LOCKS). WORKS FINE NOW!
morgenhailey
06-11-2004, 06:48 AM
have same problem. was told that the actuators are bad. go to bavauto.com they have the pair for under 200.
jeffreyb4me
06-12-2004, 08:13 PM
the actuators do fail but the handle bracket is almost as common the problem on the L/F door. lots of usage of a poor design/material issue BMW sometime runs into.
rmfigueroa
06-25-2004, 03:02 AM
I am having the same problem with our drivers side door lock assembly on our 88 735i. I replaced the actuator with a new one, but the lock assembly will not engage to lock or unlock. The passanger side door lock will work manually but not with the key. The rear doors work fine with the key in the drivers door. Is there a relay that would cause this problem? Any help or suggestion?
morgenhailey
06-25-2004, 03:16 AM
about the door problem, i have also heard of other possible culprits. 1) there is a rod in the assembly that breaks off, which if broken does not let the actuator engage. 2) the door handle itself breaks and there is no way of knowing until you disassemble it. i have not tried either of them, but it's all that i have heard about this problem. i hope it helps you. best regards.
jeffreyb4me
06-27-2004, 12:07 AM
see most recent posts on locks..................jb.
