brake pads - ceramic or OEMfingercuffs 04-14-2003, 05:46 PM Hi All Anyone used ceramic brake pads in their PF? If so what did you think of them and would they recommend them over the Nissan OEM semi-metallic pads? Thanks graffix1 06-19-2003, 04:13 PM Hey All Pathfinders from 1987 to present were equiped with Ceramic pads from the factory. Nissan sells metalic pads from the dealers because of the high price of ceramic pads. I use Pro Act ceramics from Akebono on my Pathfinder. These are the true O.E. pads. Akebono made the O.E. ceramics for the factory. You get much longer pad life out of ceramics I changed mine at 69,000 miles (It is M/T). Hope this helps. JIM pharanearthin 01-07-2004, 12:11 AM I have a 1994 Nissan Pathfinder. Do you happen to know who makes the brake pads that originally comes on the rear wheels on the SUV? Thanks, fingercuffs 01-08-2004, 05:20 PM I have a 92 SE which has rear disc pads - replacements are not easy to find so I went with the OEM parts from the dealer which are a metallic composite. They are about 20% more expensive than the front disc pads as well! stickbella9 01-19-2004, 02:18 PM Rofren Disc Brakes!! These are the best pads on the market, but hey are hard to find. The only place I have found is www.eurobraketech.com call the toll free 866 number and ask for David graffix1 01-23-2004, 02:33 PM If you have rear disc pads the OE is most likely Akebono. If they are drums I would have to research them. Let me know Automotive Network, Inc., Copyright ©2012
