program a remote for a 1998 Pontiac Bonneville SE
chopper32
04-10-2003, 08:51 PM
does anyone know how to program a keyless remote on a 1998 pontiac bonneville se i wanted to add a second remote Thanks Jim
Scott 02
04-13-2003, 07:25 AM
Must PM john if you allready haven't.
Shortbus
04-15-2003, 01:02 PM
Transmitter Programming
Important
Before entering the programming mode, verify possession of all the transmitters you will be using on the vehicle. Once you program the transmitter, the memory erases. The other transmitters will not be functional until you program the transmitters again. You may program up to 4 transmitters.
Perform the following procedure when adding new transmitters or replacing failed transmitters:
Turn the ignition switch OFF.
http://files.automotiveforums.com/uploads/957484NONE.jpg
Use a fused jumper wire in order to jumper the DLC terminal 8 (BLK/WHT) to terminal 4 (BLK).
Close all of the doors.
Turn the ignition switch ON. The doors will cycle to lock.
Press and hold the LOCK button and the UNLOCK button on one transmitter. After a 30 second delay the doors will lock and unlock.
Important
Do not turn the ignition OFF or the first transmitter will become inoperative.
In order to program extra transmitters, repeat step 5.
Disconnect the fused jumper wire from the DLC.
