corner light stuckSuB_C@lero 04-10-2003, 03:47 AM does any know how to really take out a corner light in da front for a 95 accord.. i unscrew most of da bolts n da head light is loose but i still cant get it out..i tried takin the bummer off but dere are three screws under the headlight..soo i cant get to dem.. i just need to change a bulb for the corner light n its killing..y is it so hard.. can someone help mi thanks:confused: abstract821 07-06-2003, 12:41 PM This prob isn't gonna help you much, but you don't need to take the bumper off. I had a similar problem. Just take out the surrounding screws from the corner and you seriously just have to work with it. Just gently move it back and forth. It took me about an hour to get mine out cuz when they make em in the factory, they screw those bastards down hard. You should just be able to pop it out if you work with it.....good luck!!! BullShifter 07-07-2003, 02:19 AM Originally posted by SuB_C@lero does any know how to really take out a corner light in da front for a 95 accord.. i unscrew most of da bolts n da head light is loose but i still cant get it out..i tried takin the bummer off but dere are three screws under the headlight..soo i cant get to dem.. i just need to change a bulb for the corner light n its killing..y is it so hard.. can someone help mi thanks:confused: Hew lerned u how ta spoke?:icon16: :iceslolan What abstract821 posted, only 1 screw & pop the lense out. pull straight forward with both hands(gently) 1st time is hard, after that it should be a simple process - 30 seconds Automotive Network, Inc., Copyright ©2012
