Anyone know how to install Neon lights inside the car??justin@af 03-14-2001, 09:44 AM The subject says it all...I have two 10" neon blue lights from street glow...they have two wires coming from them...Anyone know how to install them? flynfrog 09-01-2001, 12:05 AM hook tha black wire to a good ground and hook the black wirte wiht a wite stripe to a switched postive Tireburner 10-03-2001, 08:43 AM Or, depending on draw, you may want to hook the power wire up to a toggle switch, then to constant 12v or ign. that way you can turn them on or off anytime you wish. Make sure you put the recommended fuse size in line on the power wire. Whitey001 08-27-2002, 04:24 AM Or u can have a cigarette lighter adapter and unplug it when u want:flash: PaulD 12-24-2002, 10:03 AM neon light draw VERY little power lil otown 09-25-2007, 03:31 AM i got 2 48in and 2 30 inch lighst for the botton of my car just want to knwo where i put the wires to so they start glowing PaulD 09-25-2007, 06:56 PM same as above ..... you will have to run a power wire into the inside of the vehicle for a switch Automotive Network, Inc., Copyright ©2012
