Pass Motor Mount Plate - Stuck...pyro4329 11-08-2009, 12:20 AM So here's the story in a nutshell. I know for a fact the pass side motor mount is bad, horrible vibration. I have removed everything from the mounting plate attached to the engine except for one bolt. It is the lowest bolt on the plate above the harm balancer and I have no clue how to remove it. It has been loosened but I can't seem to get the engine in any position to either remove said bolt or remove the plate/bolt together. Help? hundahunta 11-08-2009, 04:22 AM you have to lift the engine very high...install a jack with a peice of wood and jack the front(crank) side of the engine...it'll look scary because the engine is high but that's normal...also make sure you don't lift the engine to high or the wire for the ac high pressures switch on the compressor may break...good luck Automotive Network, Inc., Copyright ©2012
