No Heat 2006 Equinox
wz2wj1
10-27-2009, 05:37 PM
Hello, my wife's 2006 equinox heater just quit working. Very little to no heat comes out no matter what heat setting we use. Thermostat is ok ,fan works fine, AC works fine, just no heat. Checked the fuse it's ok. Is there an electronic switch or solinoid that controls a valve?? tried to buy a repair manual nobody seems to carry them. anybody ever try the electronic program manuals out there? that seems to be the only manual i can find. Take alook at this site if you have the sam problem
http://chevroletforum.com/forum/showthread.php?t=10683
http://www.topix.com/forum/autos/chevrolet-equinox/TNMHVCTE76U9HGTH4/p2
thanks
tech JK
12-12-2009, 01:51 AM
Sounds like typical temperature door has broken int your Chevy Equinox.
It is buried inside the dash. When it breaks, you have no heat. Not electrical or any other problem.
This repair takes a good 8 hours to replace the $30 door. Entire dash, carrier, and HVAC case has to come out and disasemble.
Also does this on the Pontiac Torrent.
Equinox Torrent Heater Door Problem Repair Pictures (http://www.greatautohelp.com/pontiacanswers/My-2006-Torrent-No-Heat.html)
Vats
02-08-2010, 07:23 PM
Tech JK, any idea why it just seems to be the 2006 model that has this problem. I don't see any posts on the internet for 2005 models. I have a 2008 Pontiac Torrent and hope I don't run into this in a few years time.
7D8SS
02-09-2010, 07:45 PM
I had a similar problem with my 2005. It threw up a code though. " Engine not up to operating temp" or something like that. Had new thermostat put in & had heat again. ~ Jon
tech JK
02-22-2010, 10:45 PM
Have had a few on 2007 Chevy Equinox and Pontiac Torrent.
Non on 2008 yet. Lets cross our fingers.
consultIII
02-23-2010, 01:08 AM
have seen 3 myself. scary thing is that the replacment door isn't redesigned.
unplug and remove the temp actuator motor; if the door is broken the temp door tab will fall into the heater box.
tech JK
02-23-2010, 01:25 AM
Ya, i noticed the same thing.
Hoping it is a molding problem that has been corrected. Not fun under warranty HUH ! :runaround:
http://www.greatautohelp.com/sitebuilder/images/Equinox-Torrent-Dash-2-380x299.jpg
consultIII
02-23-2010, 01:32 AM
4.4 warranty time?? that pic would be nice to route the wiring
tech JK
02-23-2010, 01:41 AM
Ain't that a joke !
A few more under my belt, might be able to make some money on that job ! LOL
P.H.
09-04-2011, 08:03 PM
I have just finished fixing my wifes heat door on her 2006 Pontiac Torrent. (Equinox sister)
I noticed that the servo motor tries to over turn the shaft on the heat door at the extream cold and hot settings. You can hear the servo working if you listen on the passengers side under the dash with the engine off and the ignition turned to on.
This probably putting undue stress on the heat door shaft. I suggest only setting the temp control one notch short of full hot or cold settings to keep from breaking another door shaft.
Hope this helps anyone that has replaced one of these or had to pay to repace one.
Tech II
09-05-2011, 10:58 AM
Quick way to check temp door, is vent position, A/C off.....feel air flow at full cold.....now go to full hot......if air flow remains the same, temp door is not moving........if it is much slower, than the door is moving....if that's the case, then you may have a coolant leak( low on coolant creating an air pocket) or plugged heater core.....but that would cause the vehicle to overheat, and you didn't say that was a problem......
