1997 SL serpentine beltGman91 10-22-2009, 06:07 PM Well i was driving around town today, stopped at a 7eleven to get a drink. I left 7 eleven started driving and heard a clicking nose, sounded like something was dragging under my car so i pulled over. I didnt see anything so i got in the car started it up and reved the engine a little. The clicking nose was coming from my engine compartent... I decided to go home and check out the problem a little further. I got here and opened my hood and checked the serp belt and it was loose, like really lose. The battery light was flashing on my dash, car was getting hotter than normal and my power steering wasnt working. What would cause the serp belt to get so loose? I dont have the tools atm to jack it up and check it out either and i need my car for work saturday morning idk what to do, could one of the pulleys have came loose? RC1488 10-22-2009, 10:35 PM Your tensioner is bad. Replace it. http://www.youtube.com/watch?v=REanRbFco4k&feature=PlayList&p=B67CC2AF235C71D4&playnext=1&playnext_from=PL&index=69 http://youtube.com/view_play_list?p=B67CC2AF235C71D4&playnext=1&playnext_from=PL&v=cU5lDkHsacM http://youtube.com/view_play_list?p=B67CC2AF235C71D4&playnext=1&playnext_from=PL&v=6a3cm4h3mUI Gman91 10-23-2009, 08:20 PM Thanks for reply RC, but i decided just to rip it out and found out it was bad. I replaced it and got it all put back together but now there is like a clicking nose when my car is idiling at about 500rpms and i give it gas. Sounds like something around the valve cover is clicking almost like a spray paint can when you shake it.. I have no idea what it is, my dad thinks its a pulley but i dont think it is. RC1488 10-24-2009, 01:26 AM Thanks for reply RC, but i decided just to rip it out and found out it was bad. I replaced it and got it all put back together but now there is like a clicking nose when my car is idiling at about 500rpms and i give it gas. Sounds like something around the valve cover is clicking almost like a spray paint can when you shake it.. I have no idea what it is, my dad thinks its a pulley but i dont think it is. What did you replace? The belt or tensioner? Gman91 10-24-2009, 12:02 PM Tensioner, but it was making this noise before i replaced the tensioner that's how i realized something wasn't right. RC1488 10-24-2009, 05:30 PM Your idle should be ~800. 500 is to low. Thats another issue. Remove the belt and start the engine. Listen for the clicking. Only leave the engine on for 30 SECONDS. Nothing more. If you hear the click, its internal to the engine. If you dont, its a pulley. Spin the pulleys by hand and see if you can replicate the noise. Gman91 10-24-2009, 09:48 PM My bad it sits at 800 in park about 700-750 in reverse. I will try this when i get some time i work the next three days so i wont have time to do it. Gman91 10-26-2009, 04:42 PM Hey RC, since i dont have the time for a few days to pull the belt and check that out what else could it be? It sounds like its coming from the top left side of the motor, isnt that where my timing chain is? Almost sounds like a loose spark plug rattling around or a rod going but if it was a rod going it would do it constantly not just at low rpms right? Jernic 10-29-2009, 09:34 PM I had that noise in my Saturn too and was the belt tensioner, I know you change it, but did you change the belt? Maybe the belt is not good. RC1488 10-29-2009, 10:27 PM Yes it is. You need to remove the belt as i posted before to determine if thats it or not. Gman91 11-01-2009, 07:53 PM I changed the tensioner, and the belt is tight. Its coming from the top middle pulley. RC1488 11-01-2009, 10:24 PM Thats called the idler pulley. A common item to go around the same time of the tensioner. Cheap fix! :) Ruley73 11-02-2009, 07:22 PM Thanks for reply RC, but i decided just to rip it out and found out it was bad. I replaced it and got it all put back together but now there is like a clicking nose when my car is idiling at about 500rpms and i give it gas. Sounds like something around the valve cover is clicking almost like a spray paint can when you shake it.. I have no idea what it is, my dad thinks its a pulley but i dont think it is. I'd have to hear the sound myself to determine what it is. Based on your description, it could just be the PCV valve working normally, and nothing to worry about. It could also just be the timing chain slapping the guides when the engine is idling. This is normal for a Saturn with alot of miles, but as always make sure there's enough oil in the engine. My car has done it for the previous ~40K miles. It currently has just over 209K miles on it. The way I drive my car at times, it should have exploded a long time ago if the chain was bad. I wouldn't think a worn idler pulley would make a clicking type of sound since there is constant tension on it. The worn idler pullies I've had to replace in the past on various cars usually exhibited a squeaking type of sound. Gman91 11-02-2009, 08:16 PM I'd have to hear the sound myself to determine what it is. Based on your description, it could just be the PCV valve working normally, and nothing to worry about. It could also just be the timing chain slapping the guides when the engine is idling. This is normal for a Saturn with alot of miles, but as always make sure there's enough oil in the engine. My car has done it for the previous ~40K miles. It currently has just over 209K miles on it. The way I drive my car at times, it should have exploded a long time ago if the chain was bad. I wouldn't think a worn idler pulley would make a clicking type of sound since there is constant tension on it. The worn idler pullies I've had to replace in the past on various cars usually exhibited a squeaking type of sound. Ok i will try and get a video of the noise so you can hear it, but it doesn't sound internal if i put my ear really close to that side of the engine. RC1488 11-02-2009, 08:32 PM Again no video is needed if you DO MY ABOVE POST and STOP GUESSING Gman91 04-13-2010, 05:10 AM Been a while since i posted, but i still haven't fixed and have the money now to do so. Last night i accidentally turned the AC on and it made it much worse, it sounds like a damn spray can being shook up. RC, i noticed you telling someone about fancy plugs in there saturn, isnt the best idea. I gave it a tune up yesterday has bosch platinum plugs and i think bosch wires, bought both of them from autozone. I also replaced the air filter and the car seems to be running a little better. Cat Fuzz 04-13-2010, 10:56 AM The Bosch Platinums will get worse. Not good plugs for Saturns. Gman91 04-13-2010, 02:05 PM What do you recommend i put in them, what about wires? Gman91 04-13-2010, 06:48 PM The plugs i pulled out of the car, ( ones the previous owner had put in ) were bosch platinum plus plugs. Gman91 04-13-2010, 07:22 PM http://www.youtube.com/watch?v=DiqA2-Fswk0 This is exactly what my cars doing. Gman91 04-13-2010, 07:25 PM Im doing an oil change tomorrow, if it is the belt, then i will go pick it up and replace it when i do my oil change. Cat Fuzz 04-14-2010, 01:41 AM I've had three Saturns and all of them ran perfect with regular ole Autolites. As far as wires go, no need to get fancy. Fancy plugs and wires are a waste of money. A good 8mm set of wires from Napa or Shucks will be all you ever needed. The Bosch wires you bought should be fine but get those platinums out of there. Cat Fuzz 04-14-2010, 01:47 AM If you are talking about the clicking noise from your original post, do what RC said and remove the belt and run the car and see if the noise is till there. Run it for a very short time only. If it is still there, you probably have a loose timing chain and it should be replaced VERY soon. If the chain breaks, your engine is toast. Gman91 04-14-2010, 04:50 AM Do you think when my tensioner went it warped my belt? And my car makes a whining noise when it's ideling but i think that is my idler pulley. Gman91 04-14-2010, 04:55 AM Ill just pull the belt and check it tomorrow, i dont have THAT much cash so i want to narrow it down and find the problem. Cat Fuzz 04-14-2010, 03:54 PM Ill just pull the belt and check it tomorrow, i dont have THAT much cash so i want to narrow it down and find the problem. Finally. Sometimes you just have to check it out for yourself. Gman91 04-14-2010, 05:26 PM My dad was helping me do my oil change today and since he was smaller he got under the car to find the oil filter, well he thought the tranny filter was the oil filter so he unscrewed it, do i have to replace this now since the seal was broken? Cat Fuzz 04-14-2010, 07:12 PM No. Just screw it back on. Hand tight only, just like the engine oil filter. Wouldn't hurt to replace it, though. Saturn automatics do not like old filters and fluid. Automotive Network, Inc., Copyright ©2012
