Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Integra
Old 10-22-2009, 10:47 AM   #1
decprelude
decprelude Normal reputation
cold temperature gauge
Hello,
I've been having a problem with my 95 integra GS-R running cold(at least, I think it is). I've searched the forums but can't seem to find a solution.
Symptoms:
temp gauge at or near C
luke warm, not hot, heat from vents
no vtec
temp needle falls when heat turned on
temp needle falls when cruising on highway
car seems to idle normally(~900rpm) after several minutes
worse MPGs on last fillup(usually 30+, now 26)
fan will turn on with the A/C
If I sit and hold the rpms at about 3K for maybe 10 mins the needle will at most move up to about 1/8 and the fans will come on briefly. As soon as I lift off the pedal the fans go off and needle returns to C and never climbs again.
Tried:
replaced thermostat(twice)
repaced temperature sensor
Everyone I've asked seems to think that I need a new thermostat, but I've replaced that twice. I think the gauge is working since it will moves and doesn't simple sit on C. Also, I don't get any heat.
Any ideas? Any help would be greatly appreciated.
Thanks.
decprelude is offline   Reply With Quote
Old 12-09-2009, 09:45 PM   #2
Shafto
Shafto's Avatar
Shafto Normal reputation
Re: cold temperature gauge
that is wierd. If you got a couple of thermostats laying around I guess you could try and get one closed shut (wont open) and stick it in there and see if you can get any heat.
Shafto is offline   Reply With Quote
Old 12-10-2009, 07:41 AM   #3
decprelude
Shafto,
The problem was the temperature gauge sending unit. I still can't explain the MPG drop. Maybe I drove it harder than I remember during that tank.
Old 12-11-2009, 04:08 PM   #4
Shafto
Shafto's Avatar
that is really wierd, I would think that it would still get up to running temp and all, the thermostat should work independantly from the other systems I would think.
Good to hear you are rockin now.
Bookmarks
Tags
gauge, heater, sensor, temperature, thermostat
Google
Web AF
