overheatingshock712000 10-20-2009, 04:00 PM i changed waterpump therm and still seems like the water wont circulate no water in oil or no smoke from exhaust someone told me the coolant system may need bled any help please ghutchin 10-20-2009, 06:46 PM Check your coolant bypass hose. It connects to the top of the reservoir tank. If you disconnect it while the car is running there should be a steady flow of coolant. If not, then there is a clog. The northstar is self bleed through that line. shock712000 10-22-2009, 06:24 PM thanks for info ill try that peeweewasblue 10-27-2009, 02:56 AM A bad radiator cap can cause cause overheating problems. Automotive Network, Inc., Copyright ©2012
