mk3 gti missfires
ashjonwil
10-13-2009, 05:05 PM
I've got a 97 gti...all seems ok untill i drive it hard...it should Red line at 6k but it gets to 5k and starts to missfire just like its on the limiter:headshake:headshake:headshake:headshake:he adshake:banghead: any pointers anyone
cheers ash
Franco2112
10-13-2009, 05:17 PM
Just for starters, check the wear on your timing belt.
ashjonwil
11-21-2009, 11:11 AM
had the timing belt done and changed dizzy,plugs and leads still no better.....!
beardy 83
02-19-2010, 06:03 PM
cheers ash
start with the basics if the plugs leads or dis are in poor con it will only take one of these to fail under load and the miss fire will raise its ugly head if all of the above r in good order then time 2 spend money book it in 2 vw get a health check on the injectors cos at least one is not doing its job
Gtivr698
05-19-2010, 04:04 PM
i had the same exact problem, it was my spark plug wires, Vdubs are very sensitive to spark, one little fray in your wire could screw the whole thing up, so start with plugs, wires, and then it could be ur coil, if its not that then cam shaft might now be moving,
Gtivr698
05-26-2010, 04:07 PM
no it wouldnt missfire do to the wear on timing belt, and mk3's have timing chains, well least the driver editoin does, and even still all the timing would do would screw up ur throttle reaction, i can guarntee its your spark plug wires
