Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Caravan/Voyager
Old 10-07-2009, 06:59 PM   #1
allenprimo913
allenprimo913 Normal reputation
picture of a RESONATOR
i want to replace my 3 back spark plugs on my 1998 minivan plymouht voyager but its too much parts on the way
the service manual says remove the RESONATOR nd some intake STRUT
WHAT AND WHERE ARE THESE PARTS LOCATED?
i see the alternator is in the way for the number 1 but i think i can go around it but no luck for number 3 & 5 plugs.
a diagram would be great.. THANKS A MILLION
the front 3 were easy , the back are still there
HELPP!!!!!!!!!!!!!
allenprimo913 is offline   Reply With Quote
Old 10-07-2009, 08:45 PM   #2
The_Mechanic_33
The_Mechanic_33's Avatar
The_Mechanic_33 Normal reputation
Re: picture of a RESONATOR
Remove the air intake resonator from the throttle body and air cleaner assembly.
referring to a (bracket) at the rear end of the intake manifold which is strut-like in that it connects the rear surface of the cylinder head to the intake manifold plenum, near spark plug #5. It's purpose is to mechanically support that end of the intake manifold
The_Mechanic_33 is offline   Reply With Quote
Old 10-07-2009, 09:34 PM   #3
allenprimo913
ok thank you , i will look it up in the morning
so by this set aside , i would be able to have access at the plugs , i dont have to go underneath the van, right?
tnks
Old 10-08-2009, 06:22 PM   #4
Bear
Bear
Another solution is tor remove the windshield wiper tub (that part with the grill in front of the windshield and the tub below it), and NO you do not have to go under the car.
Bear is offline   Reply With Quote
Old 10-08-2009, 11:22 PM   #5
allenprimo913
i will try that and let you know
thank you for the infos and replies
Old 10-09-2009, 02:48 PM   #6
allenprimo913
i tried taking the grill out but too much work on the bottom portion
i will try the resonator tomorrow
tnks for the infos
Old 10-11-2009, 11:22 PM   #7
allenprimo913
it took me 1hr to take 1,3,5 plugs out, after i finally figured out the resonator and intake manifold bolt to the intake manifold plenum.
heres what i did:
for #1 plug
A. loosen (1)bottom alternator bolt, remove (1)top alternator bolt, then
removed the bracket that holds the alternator, swing the alternator back
then take the plug out.
*Note: i didnt have to take the serpentine belt like the manual says.
for #3& 5 (i was confused about the RESONATOR ) A>K>A BRACKET that holds the
intake manifold.
A. Removed the bracket bolt from the side of the cylinder head and loosen
the top bolt from the intake then swinged away the bracket out and
replaced the plugs.
*Note: its easier and faster if you take the air cleaner assy and the bracket that
holds the Gas cable which what i did.
hope this helps ...
Bookmarks
Google
Web AF
