95 wiil not startBADWENCH 10-04-2009, 01:51 PM Have a 95 with 3.8 SC with 119K. Had a leaking intake gasket and would run ruff. I replaced the intake gasket as well as the SC gasket, also put in new plugs. Now engine will not start. Have 40 PSI at fuel rail, have spark when I crank. While cranking what type of vacuum should I have? Would you check at the vacuum tree on top of SC. I assume you must have vacuum for the fuel regulator to work? I have sprayed WD40 around the intake and head mating parts thinking maybe I still had a leak but that did not help. Thanks for any help maxwedge 10-05-2009, 06:49 AM Are the injectors pulsing? BADWENCH 10-13-2009, 02:24 PM No, but do have power to them, so it must be whatever tellsthem to pulse. I even pulled the rail hooked the fuel line up and applied 12 v with ground and each would spray, so not what sure to check next. maxwedge 10-13-2009, 07:39 PM Fuse bad, something unplugged? Automotive Network, Inc., Copyright ©2012
