Tension Pully...
diezelman
10-03-2009, 04:45 PM
I finally got tired of the embarrassing squeak coming from my Ranger. I narrowed down the squeak to the tension pulley. However, when I replaced the pulley, (not the assembly) the belt wants to slip to the edge of the new pulley and hang off about 1/8 of an inch. The only thing keeping the belt from slipping off is the grooved/guided pulley next to the tension pulley. So it makes a noise like the belt is hitting something, and I can see the belt skip a little. I ended up putting the old pulley back on for now since I didn’t think this new one would pan out so well for me.
Is this because of too much wear from the tension assembly? The belt is only a month old. Would a different belt help, or is it just the aftermarket pulley?
This is for a 98 3.0 with 96k miles on it. A/C and 4x4
Any thoughts/advice would be greatly appreciated.
rhandwor
10-03-2009, 09:29 PM
Check the directions that came with the pulley. Was a spacer left out.
Advance and Auto Zone sell complete a tensioner with pulley. Sometimes replacement pulleys are different and the dust cover has to be removed.
diezelman
10-04-2009, 11:49 AM
There was only the pulley that came, no directions or any other devices. I'm sure I will end up having to just replace the assembly, but thats what I wanted to avoid. It's not the easiest to get to. I cant even see where to remove the bolts holding it in.
JP
rhandwor
10-04-2009, 06:49 PM
Is the bearing in the center of the pulley so it could be turned over so the belt would be in the center of the pulley.
I purchased one from Advanced and it came with instructions. You can always try another brand. Take your old pulley with you.
diezelman
10-05-2009, 01:33 PM
I bought my pulley from O'riley's. I will try one from Advanced and see if that makes a bit of a differance at all. Thanks for the advice guys.
JP
diezelman
10-05-2009, 03:01 PM
That did the trick. The surface of the pully was to rounded I am guessing. Auto Zone haad one much more similar to the stock one. Thanks for the help guys.
JP
Make 'em Last
11-20-2009, 09:54 AM
Glad you got it taken care of. Replaced the idler pulley and tensioner pulley assembly on both of my Rangers. Had to use a knife to scrape some of the inside edge of the idler pulley to get it to clear the mounting bolt washer - it was concave. On one tensioner pulley assembly, had to file the sides of the "nub" that fits into a slot against the engine (keeps the assembly from rotating after install) - it was too big for the hole.
Our examples show importance of careful visual inspection before, during & after the repair.
