Re: 1990 Fullsize jimmy low speed vibration.
does the truck have aggressive tires on it? and do you know if it was heavily used in the woods? reason i ask is because when i installed a loc-rite or really any spidergear replacement locker there is a clunk upon heavy acceleration and pretty much all deceleration if you let your foot off of the pedal completely. probably not the issue but you said it was lifted, it could be something like this.
more likely the clunking is a bad u-joint but you should in theory hear the clunk everytime you put the truck in reverse or drive (automatic). you could test this by parking on even ground and putting the truck in Neutral (chock the wheels just in case) and get under the truck and start shaking the driveshafts around. any movment at all dictates bad parts. If you can move either side of the driveshaft at a union then the u-joint is bad. if you can move the slipyoke at the back of the trasfercase you could have an ovalized yoke or the spline could losening up.
rule out the simple stuff first start with the driveshafts and move outward.
List of possiblilties:
- u-joint(s)
- bad yoke
- bad pinion bearing (rear)
- hubs are still locked (bad front d-shaft angles)
- lunchbox locker (have slop to work correctly)
- axlewrap (very slim chance)
- bad shock bushings somewhere
1989 K5 Blazer
-6" susp. lift
-35x12.5R15's
