HELP 2002 alero overheating
hanybop
10-02-2009, 08:32 PM
Hi I need some advise here. i have a 2002 alero with a 2.2 engine. and it is overheating. i have changed the thermostat twice and replaced the waterpump and still it overheats is there something i am missing here? any help would be great
Thanks Paul:runaround:
cooter2
10-29-2009, 01:54 PM
are the fans turning on when it gets hot?
2004alero
01-19-2010, 10:43 AM
i had same issue mine was resolved. i replaced the thermestat 3 times no luck checked for vacume leaks ect. you might have air in your radiator line on the rail thier is a nut but i left the cap off. start the car if you see bubles then you got air in the line. let all the bubling to stop then add to your line if needed. or take nut off and get sprayed; lol. this stoped my car from over heating hope it helps you.
2004alero
01-19-2010, 10:45 AM
robb20102010
03-10-2010, 07:53 PM
check the oil for water in it and check the radiator for oil in it. could have a blown head gasket or busted head.
