1997 sw2 won't startdusty254 10-02-2009, 04:21 PM i have 1997 sw2 that won't start i have checked the ects and its not cracked and its is the brass one checked the spark from the tower on the 1 and 4 so the crankcase senor is working tried wot. i did replace the spark plugs with differnt ones that are not nkg ones also tired spraying ether into the air entake.. the car does crank RC1488 10-02-2009, 04:51 PM Type of plugs? Anything but NGK Coppers can give you a no start situation. dusty254 10-02-2009, 05:12 PM saturn tech that the plugs don't matter and just plain jane autolite plugs dusty254 10-02-2009, 07:55 PM cound not buy ngk plugs tonight tried ac delo rapied fire plugs and still no start. the plugs i took out were wet with gas. any other ideas? Mr_saturn 10-03-2009, 11:24 PM Have you checked your ignition module? dusty254 10-06-2009, 05:36 PM no did not check ignition module yet but air is coming out of the intake manfold not being sucked in when cranking is this a sign of out of timming?when trying to take of crank case pulley was holding one cam so the pulley won't move but the other cam turned not a full rotation i think, but we stop short of pulling chrank case cover off because it was the valve cover gasket leaking not the head so the timming chain was never taken off... but to i have a timming issue? RC1488 10-06-2009, 05:41 PM no did not check ignition module yet but air is coming out of the intake manfold not being sucked in when cranking is this a sign of out of timming?when trying to take of crank case pulley was holding one cam so the pulley won't move but the other cam turned not a full rotation i think, but we stop short of pulling chrank case cover off because it was the valve cover gasket leaking not the head so the timming chain was never taken off... but to i have a timming issue? What? Please use at least a period and some sort of proper sentences. There is no crank case. You should NOT be able to turn the cams individually. Do a compression test to verify timing. If the timing is off, you will need a new engine as these are interference engines. dusty254 10-06-2009, 05:56 PM we did test for compression and it was around the 150. RC1488 10-06-2009, 06:10 PM we did test for compression and it was around the 150. For what cylinder? What are the compression numbers for each cylinder? dusty254 10-06-2009, 06:24 PM we checked cylinder 1 and 3 were 150 did not check the 2 and 4, because i did have a shop check and told me all 4 were fine when they had the car about a week ago Mr_saturn 10-06-2009, 07:30 PM Did you check the TDC alignment marks with the alignment pin holes? dusty254 10-06-2009, 08:33 PM only the marks i can see were lined up, the only marks i could see were the ones on the top camshaft sprockets and on the chrankshaft pulley. i could not see the bottom sprocket because the cover or chain was not removed. but trying to get the crankshaft pulley off i held one camshaft so the pulley would not move and the other camshaft moved not the camshaft sprockets or chain just the camshaft it rotated maybe half or a little more. i did turn the rotate the crankkshaft by hand and got no resistance it turned fine no noise or anything. RC1488 10-06-2009, 09:10 PM the other camshaft moved not the camshaft sprockets or chain just the camshaft This suggest the cam shaft sprocket and Cam shaft are not connected. The bolt holding it may be loose somehow. i did turn the rotate the crankkshaft by hand and got no resistance it turned fine no noise or anything. You should not be able to turn the crankshaft by hand with 150PSI in 2 cylinders. A new compression test is needed. Mr_saturn 10-06-2009, 11:10 PM no did not check ignition module yet but air is coming out of the intake manifold not being sucked in when cranking is this a sign of out of timing?when trying to take of crank case pulley was holding one cam so the pulley won't move but the other cam turned not a full rotation i think, but we stop short of pulling chrank case cover off because it was the valve cover gasket leaking not the head so the timing chain was never taken off... but to i have a timing issue? OK, air is coming out from the intake manifold???:confused: in the back where the firewall is, you will find the intake manifold and front of the car close to the radiator is the exhaust manifold, right?? but if you was able to rotate one of the cams freely, that is not a good sign either. in that case, the main bearing caps feel off from your pistons, that is the only reason that you can rotate one of the cams.:confused: Mr_saturn 10-06-2009, 11:26 PM cound not buy ngk plugs tonight tried ac delo rapied fire plugs and still no start. the plugs i took out were wet with gas. any other ideas? I have a 95 saturn. Problem:won't start. Have: good gas, good spark, and all the sparks plugs wet with gas. replace all the sensors, can't solve the problem. still the same. solution to the problem: after replace the coil pack, car start and is running like new. Automotive Network, Inc., Copyright ©2012
