Nofire installed 5 compontsDEAD RANGER2.3 09-21-2009, 06:51 PM Installed coil pack.engine computer,igniton module,crank sensor still no fire,also checked fuses can anyone HELP ? hinton08 09-22-2009, 08:52 PM what bout a pick up coil? do you have fire at the ignition coil? DEAD RANGER2.3 09-29-2009, 09:05 PM Thanks no fire @either coil 4cy with 8 plugs one mechanic said check eec relay omed out both relays could not get any continuity please respond stephen hinton08 09-30-2009, 10:58 AM did you back probe the terminals on the relay? the relay is a normally open switch so it has to be engergized to complete the circuit. in other words, you'll have to have the relay plugged in. But if it still shows no continuity, you have an open. try replacing the relay inself and if that doesn't fix it, more than likely its a wiring problem or the actual ecm itself. another thing to check would be the crank sensor. if the crank sensor goes out, it disables the ignition system and causes a no start problem. usually when they go bad, oil will backflow into the terminals and cause an erratic reading. just take the sensor out and see if there is oil down in the terminals. if there is, replace the crank position sensor Airjer_ 09-30-2009, 11:09 AM http://partimages.genpt.com/partimages/50440.jpg You should have continuity between terminals 85 and 86 and between 30 and 87 with the relay removed. The only time there will be continuity between 30 and 87 is with the relay energized (turned on). I don't know what year yours is but if the relay is working than you should have power to the fuel pump relay and fuel injectors (red wire on 96) if there is power there than the relay is not the problem. Automotive Network, Inc., Copyright ©2012
