1994 probe 2.0 i4joshwertz 09-19-2009, 12:04 AM engine will not idle up when i push throttle pedal. i cleaned the iac and the maf sencor, removed the valve cover and checked tdc. on the comp stroke and removed distributor cap and checked timing all ok. also i replaced the spark plugs. i have spark but i wander if it is a bad distributor not advancing the engine shutters and wants to shut down. any help would be great. Davescort97 10-14-2009, 12:48 AM Welcome to AF! Check for a vacuum leak in the intake and PCV system. Automotive Network, Inc., Copyright ©2012
