fuse in GSRkupras 04-05-2003, 10:59 PM I was adjusting my head unit today in my 97 GSR and I had it out...didnt take out the wires or anything and before I knew it...my clock and cd player wouldnt turn on. Could I have pulled a wire out that I didnt notice or could it be a fuse and if it is which ones would work for that. casperGSR 04-06-2003, 06:07 PM did you disconnect your battery? cause if ya did you'll need to find out what your security code is for your head unit in order for it to work... usually the security code is in your owners manual, if you can't find it then you can call an acura dealership and they should be able to give it to you. As far as your fuses go though you can find them under you steering column. Hope this helps. kupras 04-06-2003, 07:35 PM No I didnt disconnect the battery. This is really weird. I checked my fuses they seemed ok. My clock wont turn on at all and I took apart some of my dash but couldnt find any loose connections. Any other suggestions? Im gona have to bring it in tommorow or something GSR 04-07-2003, 01:20 PM did you also try the fuses under the hood? check the 7.5amp "back-up" fuse. its on he firewall side, 2nd from the passanger side. kupras 04-08-2003, 03:12 PM I checked the 7.5 backup and that was the problem. Thanks so much for your help guys! york2600 04-13-2003, 05:05 PM I believe the clock is on the interior light fuse in the interior of the car. Correct me if I'm wrong though. Just start pulling them out till you get it all working. You're going to have to give Acura your VIN to get the code for the stereo if you don't have it though. Automotive Network, Inc., Copyright ©2012
