pls help with my 97 intrepidvkrandoff 09-06-2009, 07:15 PM ok heres the deal.. i have a 97 dodge intrepid 3.5L v6... it has been haveing problems with starting.. i figured out that it was a battery connection and got that fixed.. the battery is fully charged with 12.53 volts and the starter relay is good.. i had to go to get my wife from walmart today cause it would not start.. i wiggled the connections and it started so i put new cable connections on and now all it will do is click.. i put the votl meeter on it and it is good and charged i tried to jump it and it just clicks.. pls help me get it started so i can trade it off .. thanks and god bless Airjer_ 09-06-2009, 07:23 PM The solenoid on the starter is clicking? Maybe you need a new starter. If there is power to the big terminal of the starter and there is power to the little terminal of the starter with the key in the crank position and the starter isn't turning the engine over its probably the starter. One single click everytime you turn the key to the crank position thats usually the starter. A bunch of clicks in rapid succession when you turn the key to the crank position usually indicates a weak/bad battery. Automotive Network, Inc., Copyright ©2012
