2001 b18b+turbo
kittedb18bt
04-05-2003, 03:22 PM
what do u guys think a 2001 integra ls with a drag 3 turbo set up would run? besides the turbo, i want to run a fuel pressure regulator, cat-back exhaust and street tires. this is all going to be on 8psi. could anyone guess the 1/4 E.T.?
IntegraB18LS
04-05-2003, 05:46 PM
Im just gonna guess 14's but that is just a guess...
Kyle
casperGSR
04-05-2003, 06:18 PM
just so you know you don't need to buy a fuel pressure regulator because the drag gen III kit comes with the Vortech FMU.
kittedb18bt
04-05-2003, 09:55 PM
thanks casper gsr. what about if i added cam gears? would that help out in the tuning/dyno process. i just hope to get in the mid high 13's
IntegraB18LS
04-06-2003, 12:51 AM
on slicks and with all that my guess you should be possible to be in your 13's.
Kyle
jkicv
04-06-2003, 04:30 PM
hey, my buddy has the drag kit on his integra, stock clutch, which was pretty gone at the time and he ran a 13.8 in colorado. not bad at 6 lbs of boost.
whtteg
04-06-2003, 09:32 PM
You will need to upgrade the clutch especially if you use slicks.
casperGSR
04-07-2003, 09:03 PM
actually you really don't need to do much to the clutch if you're only running 7lbs unless you're gonna really be pounding on the car at the track. I had my stock clutch on my car for over 30,000 miles with the drag kit and we just swapped it with a clutchmaster and the stock clutch had a few heat streaks but not much wear on it.
whtteg
04-07-2003, 11:39 PM
Were you launching it hard at the track with slicks? Look at it this way slicks grip hella good so the weak link is now the clutch. I know my clutch started slipping with a 50 shot on street tires and that was in second gear. And I know that 7lbs should be more than 50 hp. I am just saying that he will need the upgraded clutch if he wants to use slicks.
super_man_3179
06-01-2003, 09:18 AM
you can get away with a stock clutch for a while as long as your not racing every single person that drives past you. I'd recommend the ACT stage 1 clutch and it can hold up to 243 ft-lbs. That's more than enough on drag 3 gen kit. I know that the drag kit on a 94-00 LS at 8psi produces 255 WHP and 216 ft-lbs at the wheels. And quarter mile time is 13.28 on stock clutch.....I have a link on overboost.com that they did this...here it is.
http://www.overboost.com/story.asp?id=57
That kit is the shiznit!!!! Hope that helps.
