Will my old rims fit my "new" Jimmy?
ninepointer
09-03-2009, 10:38 AM
Will the aluminum rims from my 1995 Jimmy fit my 2005 Jimmy? I'd like to use the old rims for snow tires. Thanks:)
exalteduser
09-03-2009, 12:16 PM
best way to check is the tire size, like 235/60/r15 or whatever it is. see if they are the same. the 5 lug pattern should fit
Gabe25
09-03-2009, 03:28 PM
One more other thing is to make sure that they are both from a 4 wheel drive of 2 wheel drive. If you try to put 2 wheel drive rims on a 4 wheel drive system. The tire and rimes will be pushed out side of the fender wells. Reason for that is because the rims offset are different. 4 wheel drive has a wider wheel base then the 2 wheel drive.
ninepointer
09-04-2009, 08:48 AM
Gabe,
I'm glad you mentioned that. My old Jimmy is a 2WD and my new one is a 4WD (actually it only works in 2WD right now, but that's another story:rolleyes:).
Thanks!
