Turns on and shuts off
victorc1
08-20-2009, 06:12 PM
I have a 2000 Galant 4 cylinder, when I start it, it turns on for about 30 seconds up to 2 or 3 minutes but then shuts off. If I hold the gas pedal down and turn the key it stays on as long as I keep it acelerated, when I let go of the gas it shuts off. Also when this problem started the check engine light turned on. When I put the computer on it it marks the cam sensor, but when I did the test it came out good, I also erased the check engine light and the car ran fine for 1 day and started the same problem again.
cougar214
09-01-2009, 10:47 AM
Check your harness wires on the cam sensor...they may be frayed or loose...My brother had this same problem and it was the wires.
sandra1219
02-16-2010, 10:30 PM
having same proble did you fix it and what was it? pozopozo71@yahoo.com
