2004 x-5djm283812 08-10-2009, 04:31 PM Does anyone know how to replace the brake switch on a 2004 x-5? I checked the bulbs and fuses and all were in tact. The only thing I could think of as to why the brake lights weren't working was the brake switch. Thanks motorwerkes 10-27-2009, 03:57 PM did you test the contacts on the brake light assembly itself? sometimes i found that a little corrosion will make all lights fail. if not Replacing Brake Light Switch Necessary preliminary tasks: Remove trim panel for pedal assembly. E38 up to 09/98: http://alldatapro.com/alldata/PRO%7EV140698200%7EC38332%7ER0%7EOB0%7EP3R0H%7EN/0/101825161/103141007/103141053/103141055/34853741/34867926/34868156/34850045/110909261/110909262 Disconnect plug connection. http://alldatapro.com/alldata/PRO%7EV140698200%7EC38332%7ER0%7EOB0%7EP3R0H%7EN/0/101825161/103141007/103141053/103141055/34853741/34867926/34868156/34850045/110909261/110909263 Depress brake pedal as far as possible, using pedal support if necessary. http://alldatapro.com/alldata/PRO%7EV140698200%7EC38332%7ER0%7EOB0%7EP3R0H%7EN/0/101825161/103141007/103141053/103141055/34853741/34867926/34868156/34850045/110909261/110909264 Pull tappet and sleeve forward completely. Press together clips and pull back switch. Installation: Slowly bring brake pedal into initial position. E38 from 09/98, E39, E52 and E53: Installation: On E38 Series RHD cars with ACC from 04/2000 and on all cars with DSC: A gap of 0.7 mm must be adjusted between brake pedal and brake light switch. If this gap fails to guarantee problem-free operation, the gap must be reduced to 0.6 mm . Unfasten plug connection (1) and disconnect. Pull brake light switch (2) in direction of arrow out of brake light switch holder (4). Installation: Press brake pedal (3) to floor. Slide brake light switch (2) as far as it will go into brake light switch holder (4). http://alldatapro.com/alldata/PRO%7EV140698200%7EC38332%7ER0%7EOB0%7EP3R0H%7EN/0/101825161/103141007/103141053/103141055/34853741/34867926/34868156/34850045/110909261/110909265 Grip brake light switch holder (4), slowly return brake pedal (3) to starting position and pull back to stop. NOTE: Removing brake light switch holder (4): Press brake pedal (3). Press catches together and unclip brake light switch holder from brake pedal (3). http://alldatapro.com/images/blnk_spc.gif © 2009 ALLDATA LLC. All rights reserved. Terms of Use (http://alldatapro.com/alldata/PRO%7EV140698200%7EC38332%7ER0%7EOD%7EN/0/101825161/103141007/103141053/103141055/34853741/34867926/34868156/34850045#foot) Automotive Network, Inc., Copyright ©2012
