Change Oil Indicatorshanilf 08-04-2009, 11:10 PM Need some help please I have a 2006 uplander which just ran out of warranty. I did my first oil change at home. I need to get rid/reset the "change oil" indication. I have looked around the web but have not found an answer...does anyone know???? '97ventureowner 08-04-2009, 11:28 PM On your DIC when you bring up the OIL LIFE INDICATOR, just press the button on the dash next to the DIC with the arrow on it. You need to hold that button down until the system resets itself to 100% ( or 99% in some cases.) Airjer_ 08-05-2009, 12:23 AM Page 443 of your owners manual How to Reset the Engine Oil Life System The Engine Oil Life System calculates when to change your engine oil and filter based on vehicle use. Anytime your oil is changed, reset the system so it can calculate when the next oil change is required. If a situation occurs where you change your oil prior to a CHANGE OIL SOON message being turned on, reset the system. 1. With the ignition key in RUN but the engine off, repeatedly push the set/reset button until OIL is displayed on the Driver Information Center (DIC). 2. Once OIL is displayed, push and hold the set/reset button for five seconds. The number will disappear and be replaced by 100 (indicating 100% oil life remaining). 3. Turn the key to LOCK. If the CHANGE OIL SOON message comes back on when you start your vehicle, the engine oil life system has not reset. Repeat the procedure. Automotive Network, Inc., Copyright ©2012
