99 Saturn SL Won't Start!turtleisland 08-04-2009, 07:45 PM I have a 99 Saturn SL and its got 150,000 or so miles on it. It has been running high rpm between 2 and 3 when I put it into park after driving for a while, so I just shut the car off and Ignored it. Until yesterday morning when I started the car and got halfway out of the driveway and it stalled. The radio still works, beeps still work, all battery powered stuff still working. I tried to start it again and just got a chug chug chug.. engine wouldnt turn over. So I tried again today and am getting the same but sometimes with a slight combustion but the car doesn't start. And I smell gas after trying to start the car maybe because its flooded. Every time I try I get the trying to start chugging noise and a little combustion .. and then the gas smell. I need to change the oil filter on it. I just filled her up with gas the day before and it rained all day and night. I have a sneaking suspision it has something to do with those high rpms after putting it in park though.. and the fact that the transmission has been acting a little faulty, meaning that 3rd gear takes forever to shift up to fourth. It's an automatic. Please help! What is wrong with my car???? Anyone? Aloha :) Thank you for your time! RC1488 08-04-2009, 08:40 PM This is what happens when you let the little things go!! Your ECTS is bad. It cracked a while ago and now most likely cracked even worse possible ruining the connector. New one can be bought from Autozone for 10 bucks. Install it. Then hold the pedal down at Wide open throttle. This shuts off the injectors so that excess fuel will be burned. Eventually it will start up. OR you can remove the spark plugs, crank the engine over a little, then reinsert the plugs. It also should start right up after that. The ECTS is VITAL to many subsystems of the car; Idle rpms, fuel ratios, tranny shift points, Torque converter lock up points, fan control, ..etc etc. When it cracks it tells the PCM the engine is cold thus the PCM make the mixture extremely rich, raises rpms, and will not allow the car to shift so that high rpms are sustained inorder to warm the engine up faster so that on board emissions tests can be completed and passed. If the connector has antifreeze on it or is corroded it must be replaced. Although the sensor is 10 bucks, this connector is 30 from the dealer. An Intake Air Temperature sensor connector will also work. Junkyard is the best to find replacements for the ECTS connector though. I have posted a how-to video for this in older threads. The search button is your friend :) turtleisland 08-05-2009, 06:54 PM Thank you for your reply! :) I'm sure that this is probably correct. But, I just tried to start my car again and noticed that gas is leaking on the ground, beneath the drivers side door. So, I guess theres a leak in the fuel line now! Probably pressure built up and maybe the fuel filter is clogged? I'll replace the E.. thing you said. Much mahalos friend! Aloha amanda60302 08-11-2009, 11:43 PM Hi did you ever figure out if this is the issue? Just curious as I have a 99 sl1 that was doing the same high rpm thing in park and will not start now but our issues concern the alarm and factory keyless entry system...Just thought I would ask how this worked out for future refrence lol... =0) Hope it went well! turtleisland 08-13-2009, 10:47 PM Yes I did resolve the issue. Well, at least the not starting part. It was a busted fuel line. Easy fix! I've dealt with keyless entry systems in my buick before, can be a little complicated on the newer cars. But its usually all just based resistance readings. Good luck with that! The advice given to me on an earlier reply if you scroll up, about the ECM... whatever it is called... I researched it a little and it looks like that might be a solution to the high rpm.. i think one of my PCV device readings is off too. sorry, i dont know if that was much help. if i find out more. I'll let you know. ALOHA! peace amanda60302 08-13-2009, 10:52 PM Thanks, Still have no clue what the issue is, I am about ready to give up! I hate to loose my car it really has been a trooper! I just dont know what else to do at this point and dont have alot of money to put into trying to fix it if I cant even figure out what to fix lol...Thanks again for your answer! Automotive Network, Inc., Copyright ©2012
