Taller Tires for my QX4?mario_qx4 04-03-2003, 10:24 AM I have the stock P245/70R16 tires on my QX4 and I'd like bigger tires. Can I put 17, 18, 19 inches or more rims? Recommendations welcomed! thanks Mario Luke@tirerack 04-04-2003, 07:34 AM you can plus size your QX with no problems here are some tire size selections that will work with no issues 285/55-18 255/65-16 265/50-20 245/65-17 295/45-20 255/60-17 265/60-17 255/55-18 mario_qx4 04-04-2003, 10:08 AM Thanks Luke, I'm looking for a good offroad tire, either the - bridgestone Dueler A/T REVO - or the BF goodrich all-terrain T/A KO So, for example, a bridgestone Dueler A/T REVO 265/70SR17 will have no trouble fitting ? Much appreciated! M Luke@tirerack 04-04-2003, 02:59 PM that size would be a tight fit but would probably work mario_qx4 04-09-2003, 11:33 AM You know what I'd like to know, the actual overall height difference between sizes, for example: 245/65R17 245/70R16 245/75R16 Which is taller? I'm sure the calculation is easy, I'll try to find the formula on the net.. M mario_qx4 04-09-2003, 11:51 AM Found http://www.tirerack.com/tires/tiretech/general/size.htm which lists all you need to know about tire sizes. Using their formula, it seems - 245/65R17 is 29.53" high (2003 models) - 245/70R16 is 29.50" high (stock) - 265/75R16 is 31.6" high (what I want) No how do I know if 31.6" fits on my QX4 ?? Hmm that's 2 inches more... What do you think? M Automotive Network, Inc., Copyright ©2012
