94 ford explorer will not startRobzilla 04-02-2003, 05:52 PM :bandit: My 94 ford explorer will not start,I have replaced fuel filter and fuel pump and it will only start if I prime it from the intake... I need advice please.:smoker2: kaoru-tochiro 04-02-2003, 09:14 PM prime it from the intake? what do you mean? Robzilla 04-02-2003, 10:37 PM :frog: I mean The air intake from where the air cleaner is...I can spray some eather in there and it will fire off then die...:bandit: safetyman 04-03-2003, 08:31 PM try bleeding the fuel rail it might be air locked Robzilla 04-03-2003, 11:16 PM it does have fuel to the rail, I am thinking eithre maf sensor or bad or clogged fuel injectors. Hopeing it is maf sensor:smoka: safetyman 04-04-2003, 11:46 PM can't see 6 injectors plugging at the same time, have you checked to see if you have any spark at plugs? kaoru-tochiro 04-04-2003, 11:49 PM it started when he primes it at the manifold safetyman 04-04-2003, 11:55 PM what about the fuel cut off switch, with the pressure released from the feul line will the the switch have to be reset Robzilla 04-05-2003, 03:38 PM I got fuel up to the fuel rail and I have good fuel pressure. I checked the injectors for power and When I checked the white wire the injector would click like it was not getting a ground so when I put my tester on it I wonder if I was completing the circuit? I am going to buy the haynes book for this . I will let you know what I find. pheonixx 04-12-2003, 04:01 PM firt bet since this is common on exploders...fuel pressure regulator. second would be check the fuel pump relay..(tap test it) tap test is hitting it with a screwdriver to see if it clicks over while buddy tries to start truck... good luck! Automotive Network, Inc., Copyright ©2012
