Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 07-08-2009, 11:10 PM   #1
mtbdiablo
mtbdiablo Normal reputation
Oxygen Sensor Question
Hi, I have a 2001 Silverado 2WD 5.3 liter. My "Service Engine Soon" light came on. I had someone read it and it showed error code P0137. They said the voltage is low on the low bank 1 sensor 2. Does anyone know which sensor this is? A guy at the auto parts store said he thought it was the passenger's side before the cat. I changed it and still have the SES light on. I'm wondering if that wasn't the right sensor that I changed.
Does anyone know which sensor the P0137 refers to?
Thanks
mtbdiablo is offline   Reply With Quote
Old 07-09-2009, 07:01 AM   #2
Jeremy-WI
Jeremy-WI Normal reputation
Re: Oxygen Sensor Question
With dual catalytic converters, bank 1, sensor 2 will be the post cat sensor for the drivers side exhaust, and you might want to watch the exhaust routing closely for crossing pipes
Jeremy-WI is offline   Reply With Quote
Old 07-09-2009, 11:42 AM   #3
j cAT
j cAT Normal reputation
Thanks
these O2 SENSORS ARE TO BE REPLACED AT OR AROUND the 100,ooomi of useage...the manufacturers reommend this...If you do not replace them at this mileage you will need new cat converters,and also loose power and MPG>>>>
this sensor monitors the driverside cat converter performance...this could indicate a bad cat converter,,as well as other problems,,especially wiring/connectors/ground connections etc...
before buying new sensors if they are under the 100,ooomi of useage try swapping the sensor to see if the problem DTC changes location of failure .. this then will ensure you have the problem solved exactly..
if you have over the 100,ooomi life on these sensors ,,,replacement is recommend to prevent engine/cat converter damage...and pass the emissions testing ...
j cAT is offline   Reply With Quote
Old 07-15-2009, 02:51 PM   #4
mtbdiablo
Thanks for the advice everyone. I changed out the sensor but my Service Engine Soon light is still on. Does anyone know if I need to reset this somehow or will it reset itself after a while. I'm hoping I don't have a short in a wire or something. Thanks again.
Old 07-15-2009, 02:58 PM   #5
rhandwor
rhandwor Normal reputation
Ask Auto Zone or Advanced if they will erase the codes and recheck this is a free service.
rhandwor is offline   Reply With Quote
Old 07-15-2009, 04:22 PM   #6
j cAT
disconnect the negative side battery connection for 10 min...this should reset the DTC trouble codes...
Old 07-15-2009, 06:11 PM   #7
mtbdiablo
Thanks for the suggestions. I tried disconnecting the battery for 15 minutes but still get the code. I called Autozone but they said they said that California banned them from checking codes in 2005 because they are not a licensed smog facility. Does anyone have any other ideas or do I have to bite the bullet and take it in to a shop?
Old 07-15-2009, 06:56 PM   #8
rhandwor
http://www.ntxtools.com/ Search Vendor list Innova Equus products. They just added this company.
Old 07-15-2009, 07:40 PM   #9
silveradofirerescu
silveradofirerescu Normal reputation
It will go out WHEN the problem is corrected, usually after 5-10 drive cycles.
silveradofirerescu is offline   Reply With Quote
Old 07-15-2009, 08:18 PM   #10
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
...I tried disconnecting the battery for 15 minutes but still get the code.
Disconnecting the battery might turn the SES light off. It will NOT clear the DTC's. DTC's remain in the history file until they are cleared with a scan tool, (not a code reader). The OBDII system is designed to keep DTC's in the history file in the event of battery failure so the technician is able to retrieve DTC's after battery power is restored. Have your system cleared with a scan tool and complete a drive cycle: http://www.obdii.com/drivecycle.html If the SES light comes back on, retrieve the DTC's and post them here. We can supply you with a flow chart to diagnose the problem.
The global warming agenda has never been about science or health or human life. The global warming agenda is about stripping us of our freedom and redistributing our wealth. The only things truly endangered are our rights.
old_master is offline   Reply With Quote
Old 07-15-2009, 08:52 PM   #11
777stickman
777stickman's Avatar
777stickman Normal reputation
J, I'm wondering if you have stock in the 02 sensor business? So I read thru my '98 C/K service manual and nowhere did it suggest or recommend changing O2 sensors at all. Maybe there is a TSB?
Got 150k on the '98 Sub 7.4 and still got great power and 14-15 mpg. And the original O2's (all 4 of them).
"R57 3CAR" 210 2dr post. 420HP 355 F/I 4sp 3:42 posi. (Dale Earnhardt tribute done by me.)
75 GMC Vandura 3/4 Ton
78 Chevy K5 Blazer
98 Chevy K2500 Suburban LT/7.4
05 Dodge Ram 3500/Cummins (Wifes horse hauler)
777stickman is offline   Reply With Quote
Old 07-15-2009, 09:08 PM   #12
777stickman
The P0137 code says to change the O2 sensor after checking for 7 different things.
Lean injectors, Fuel contamination, Fuel pressure, Exhaust leaks, Vacuum or crank ventilation leaks, Wiring issues to the sensor and/or VCM.
78 Chevy K5 Blazer
Old 07-15-2009, 09:09 PM   #13
old_master
Advisor/Moderator
old_master's Avatar
O2 sensors react to changes in fuel mixture. The faster they react, the faster the PCM/VCM can adjust the fuel mixture to keep it as close as possible to 14.7:1. They react both lean to rich and rich to lean. Normal driving will slow the O2 sensor reaction time down. It has been proven that after 100,000 miles the O2 sensor reaction time has slowed enough to significantly affect engine performance and fuel mileage.
Old 07-16-2009, 10:54 AM   #14
j cAT
you are absolutely correct,,,nowhere in any GM repair manual will you see this 100,ooomi replacement...the reason for this is GM wants all to believe at this mileage the vehicle life is ended...so why put this instruction in the repair /owner guide book///???
when I stated this 100,000mi limit ,,this is not my opinion....
this is the O2 sensor manufacturers....that is why it is hard for me to understand why owners insist on having the O2 sensors tested when OVER the 100,ooomi point..
why don't they replace one spark plug at a time when ever it starts missfiring ??or bring it in for a diagnostic scan to find the bad plug ?
owners screw around thinking their saving money by ignoring this life limit on these devices...in the end the engine runs poorly, uses more fuel, less power, more pollution , and the cat converter gets destroyed...
ITS THEIR VEHICLE AND THEY ARE THE ONE'S SUFERING FROM THEIR ACTIONS...OR SHOULD I SAY LACK OF ACTION ...
it also says if you do normal driving replace transmission fluid at 100,ooomi...and other stupid stuff..
Old 07-16-2009, 11:03 AM   #15
j cAT
you never posted,,,DID YOU PUT THE NEW O2 SENSOR IN THE DRIVERSIDE DOWN STREAM[AFTER CAT] LOCATION...
I believe they stated the passenger side was where it was to go,,,,, this would be incorrect with a PO137 DTC....
Bookmarks
Google
Web AF
