Re: Cooling Fan Dropping Resistor - UPDATE - Problem Solved
Hello-
After further research - and putting together clues from different threads - I was able to locate the elusive dropping resistor for the cooling fan.
I believe this info is good for '99 right up to and including Freestars - I'm not sure this also applies to the '98 model year.
So- if you remove the left front headlight assembly - and look into the hole that the parking light / directional signal socket is threaded through - you will see the resistor mounted to the inner fender wall. Access is attained by loosening the plastic fender well liner. Hope this helps out
Good Luck-
Glenn
