Whistling @ 2500 RPMVinceH 07-07-2009, 03:42 PM All, I have been having a whistling sound everytime the engine rev's to 2500 RPM and above, it will gradualy decrease around 3500rpm. I oringinally thought this was due to the IMG but I have since replaced it and the should is still there. I have no codes that pop up either. any advice would be appreciated. thanks 2000 Rodoe V6 126k miles wheelman1917 07-07-2009, 04:05 PM Can you duplicate the problem sitting still. You can operatate the throttle under the hood and possibly find it. amigo-2k 07-07-2009, 09:15 PM sounds like a classic intake manifold gasket issue. see the FAQ link below. VinceH 08-04-2009, 04:23 PM Intake manifold is new, I had the wife accelerate it to over 25k rpm and I can not recreate this sound while the car is in park or in nuetral. Very strang. any other thoughts? I am at a loss.. Thanks:banghead: stantony1 10-02-2009, 02:49 PM I had a buzzing noise at 2500 RPM and only during driving. It was loose heat shields that resonated with the the car vibrations at 2500 RPM. Re-attached with hose clamps. RIght up around the exhaust manifold and near the cat converter. That stopped the buzzing noise. Otherwise check the seating on your airfilter. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
