Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Caprice
Old 07-06-2009, 09:06 PM   #1
kshook.2
kshook.2's Avatar
kshook.2 Normal reputation
95 lt1 roller rocker arms
i had the roller rockers on my old cast iron head lt1 i just put a new aluminum head z28 lt1 into my caprice and i tryed to put my comp cam roller rockers on it and they slip off the tip of the valve and right onto the spring ive tryed to a just them but it dont help any one have this problem any help would be good they never sliped off like that on the cast head motor
kshook.2 is offline   Reply With Quote
Old 07-07-2009, 08:11 AM   #2
rhandwor
rhandwor Normal reputation
Re: 95 lt1 roller rocker arms
Talk to your local machine shop for advise.
rhandwor is offline   Reply With Quote
Old 07-07-2009, 05:44 PM   #3
96capricemgr
96capricemgr Normal reputation
Can you post a picture of the rockers?
I wonder if you used the WRONG non-SA rockers but the tight slots on the iron heads allowed it to function.
If that is the case you will need guideplates and new studs.
You know stock for stock the aluminum heads are NOT an upgrade?
96 Caprice Medium Garnet Red
ported heads, custom cam, stock shortblock 11.95 at 113mph, daily driver in fair weather months.
95 Roady wagon 208K miles and still going strong
96capricemgr is offline   Reply With Quote
Old 07-10-2009, 05:14 PM   #4
96capricemgr
Would like to help. If you can't post pictures I can send you an email addy.
Old 07-10-2009, 08:50 PM   #5
kshook.2
kshook.2's Avatar
here is a pick they are 1.6 comp cam roller rockers
Old 07-11-2009, 12:16 AM   #6
96capricemgr
Can you flip one over or take a profile shot?
What I am looking for is tab that would hold the roller tip on the valve.
Some brands use a washer on either side of the roller tip but Comp ProMagnums have a tab.
I tried to find a picture of what SA ProMagnums look like but no luck finding one.
Old 07-11-2009, 11:13 AM   #7
kshook.2
kshook.2's Avatar
well i called comp cam they said i need guide plates for these rockers i did not know that.
Old 07-11-2009, 09:06 PM   #8
96capricemgr
as I expected
Old 07-13-2009, 11:01 PM   #9
96capricemgr
Should be said that Comp guideplates do NOT fit properly. LT1 valve spacing is a little different. Seems like the best "budget" solution is Trickflow. I went a step further with Isky adjustable.
Bookmarks
Google
Web AF
