Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nonspecific
Old 07-05-2009, 09:35 PM   #1
Lukewarm256
Lukewarm256 Normal reputation
testing for stuck injectors.
i have 2 cars with what i think may be simular problems... stuck injectors. One, a chevy, probably has them stuck open, and the other, a ford, might have one stuck closed.
SO, the general question is--what's a good, easy way to find out which injector is stuck on a mpfi v6? anyone got some cheap suggestions?
thanks in advance.
Lukewarm256 is offline   Reply With Quote
Old 07-06-2009, 06:12 AM   #2
rhandwor
rhandwor Normal reputation
Re: testing for stuck injectors.
You can take a long screw driver put on the side of the injector and listen.
http://www.autopart.com/tools/toolsmain/tool/T_2015.htm
http://www.ntxtools.com/ search WAE-76400
Use an ohm meter and ohm each one.
http://www.autopart.com/TOOLS/TOOLSMAIN/tool/T_3401.htm
I would check for power to the injector first.
rhandwor is offline   Reply With Quote
Old 07-06-2009, 10:02 PM   #3
wafrederick
wafrederick Has more negative feedback than positive
Tap on them with a small hammer.
wafrederick is offline   Reply With Quote
Old 07-29-2009, 01:19 AM   #4
jetsfan1128
jetsfan1128 Normal reputation
Send a message via AIM to jetsfan1128
use a noid light its cheap and gives you info then if it checks out there screw drivers the way to gobut like previously stated ck w/ noid light first
jetsfan1128 is offline   Reply With Quote
Old 08-04-2009, 12:00 AM   #5
SS402
SS402 Normal reputation
Remove the connector from the injector while the engine is running, if there's no change in rpm you've located a/the misfiring cylinder, to verify that the selected injector is bad you have to rule out the valvetrain and ignition, if you have a injector pulser you can manually check each injector for correct operation
SS402 is offline   Reply With Quote
Bookmarks
Google
Web AF
