Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 07-05-2009, 04:41 PM   #1
Bailesie
Bailesie Normal reputation
'03 Cavalier with slight ticking (Lifter? Timing? Tensioner?)
It's easier to post a video I took in order to convey just what exactly my car is doing. It's been this way for about two months and hasn't gotten any worse, thankfully *knock on wood*
Please check it out and let me know your thoughts.
http://www.youtube.com/watch?v=Gs2SkIowmwQ
Thanks!
-Shawn
Bailesie is offline   Reply With Quote
Old 07-05-2009, 11:35 PM   #2
J-Ri
J-Ri's Avatar
J-Ri Normal reputation
Re: '03 Cavalier with slight ticking (Lifter? Timing? Tensioner?)
Alright, a video! Much better than hundreds of words comparing noises to things I've never heard.
Pull the belt off just to make sure it's not something belt driven. Get an automotive stethoscope and listen around and see where the noise is the loudest. A long screwdriver with the handle held to your ear will work, but the stethoscope works much better. It sure sounds like the chain is loose and slapping around inside the cover, but I had a 2.4 "Quad-4" that made a very similar sound up until it threw a chunk of a rod through the side of the block.
Also, get that Lucas out of there. It foams up going through the oil pump and some of the oil is replaced with air... not good for anything lubricated. Their display at the auto parts store looks great... and it probably would be if your engine was a hand crank operated at 100 RPM
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
J-Ri is offline   Reply With Quote
Bookmarks
Tags
chain, lifter, tensioner, ticking, timing
Google
Web AF
