Hello up there in Retirement Living Heaven
Here's my two cents...
Short Answer
Try jumping that Engine Coolant Temp Sensor (ECT) again, but with the motor running.
Long Info About Your Cooling Fan Wiring
As you know, in terms of the heating and cooling system, the cooling fan is controlled through the
PCM (Powertrain Control Module) receives info the
A/C Pressure Sensor, the
Engine Coolant Temp Sensor (ECT) and the
Instrument Cluster (Microprocessor).
1.
A/C Pressure Sensor - 3 wires (
Red/Black stripe,
Grey, Black) running to the PCM. This seems to be working fine, because when you turn on the A/C you get the cooling fan. The wiring diagram shows that turning on the A/C switch connects the ground to the
Light Green wire which runs to the microprocessor, which in turn sends the signal to the PCM via a
Tan wire. The PCM then sends power to the cooling fan relay via 1
Dark Green wire (which is grounded through the fuse which is hot at all times) turning the fan on through that single
Light Blue wire.
2.
Engine Coolant Temp Sensor (ECT) - 2 wires (
Yellow, Black) running to the PCM. I think this is the sensor you were talking about, just to confirm - This is located on the coolant pipe at the right front corner of the cylinder head right behind the alternator. The engine might have to be running for this to work, I can't tell from the diagram.
3.
The Instrument Cluster (Microprocessor) -
Tan data wire from processor to PCM. Sends signals from all the temp control settings from the passenger compartment.
4.
The A/C Compressor Relay Control -
Dark Green/
White stripe. Consists of the A/C Comp Clutch Relay
which is connected to the A/C Comp Clutch (Dark Green wire) and the A/C Clutch Diode (Dark Green wire) This doesn't have much to do with the cooling fan. The PCM gets this info from the Microprocessor telling it to turn on/off the a/c compressor.
Hope that helps out.
