Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 07-04-2009, 09:40 PM   #1
302Z28
302Z28 Normal reputation
code P0325
I have had driveability problems for a long time with my '97 2.2 Cav (stuttering & stalling). Finally, a friend diagnosed it as a ECM computer module the was not functioning. I bought a rebuilt, pre-flashed ECM and installed it. I performed the anti-theft re-learn and the vehicle runs great!
A short time later the check engine light came on. A-Zone read the code
as P0325 (knock sensor). They also mentioned that there is no way to test the sensor, but for about $30., they would sell me a replacement, that may or may not solve the problem.
Could anyone please tell me where the sensor is located?
It seems odd that there were no codes with the old ECM, but codes almost immediately after installing the new ECM.
Any advice will be greatly appreciated.
Thanks,
302Z28 is offline   Reply With Quote
Old 07-05-2009, 01:15 AM   #2
J-Ri
J-Ri's Avatar
J-Ri Normal reputation
Re: code P0325
Things can go bad at any time, may have gone bad with the old pcm too.
You can check with a Tech-2 scan tool to see if it's bad... but you probably don't want to spend thousands on that...
Just check that the wires to it are good, every time I've seen that code it's been the knock sensor itself. The code sets when there is no voltage from it, it's a crystal that generates it's own mV. Should have a "vibrating" voltage if you can check it with a volt meter.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
When you buy something... a bottle of pop for example, who gets the profit from it and what do they do with it? Maybe your money's going to groups that want to hurt you. I think everyone should do a search for things they purchase regularly "____ supports". Might just find a company you won't buy stuff from anymore.
J-Ri is offline   Reply With Quote
Old 07-10-2009, 08:12 PM   #3
Smythers00
Smythers00 Normal reputation
Re: code P0325
Knock sensor location:
Back side of the engine block right next to the Camshaft Position Sensor (CMP) by the exhaust manifold.
Also, for the record, there is a way to test knock sensors... you need two things, a multimeter and the circuit resistance rating for the sensor. Essentially, buy an new knock sensor, test the resistance, then compare to the old one. If the same, KS is not the problem.
Smythers00 is offline   Reply With Quote
Bookmarks
Google
Web AF
