89 astro van abs brakescruz7876 07-04-2009, 08:24 PM Code 2 on 1989 astro van abs system. New master cylinder,new proportioning valve,new abs modulator valve,new rear wheel cylinders.could this cause by unproper bleading,or abs module problem. cruz7876@bellsouth.net denni49 07-05-2009, 10:33 PM Code 2 on 1989 astro van abs system. New master cylinder,new proportioning valve,new abs modulator valve,new rear wheel cylinders.could this cause by unproper bleading,or abs module problem. cruz7876@bellsouth.net what does code 2 stand for? have you tried clearing the codes ? and seeing if the problem crops up again. also a 89 is rear wheel abs only with intergated oil resoivoir. try unpugging porportional valve plug ,next e break switch. reset abs fault codes . you may need special tool to properly bleed brake modulair? I have a 92 astro van with a code 65- open relay curciut at booster pump motor, i sucessfully cleared the code and havent had any problems so far good luck vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
