I'm wondering if anyone has any experience with installing H3 rims on a 'Burb...
I just acquired a 1999 K1500 4x4 Suburban and the tires need replacements. I ordered some 245/75/R16 Bridgestone Blizzak DMZ3's for it off Tire Racks website, taking advantage of a great "closeout" deal.
I came across a set of 2006 H3 rims yesterday, and scooped them up for peanuts knowing the 6-lug bolt pattern was the same.(6x5.5)
I still have to test fit them for clearance but thought I'd ask first...
Do you think it'll be a problem that the center bore of the H3 rim is the larger 100mm size rather than the Suburban's 78.3 c.b.??? Will this cause the load of the vehicle to be dangerously carried solely by the studs, without the help of the pilot on the drum and rotor? I realize both rims are lug-centric, not hub-centric...I'm just concerned.
Stock Rim 78.3mm CB
H3 Rim 100mm CB
Will I run into any clearance issues due to the wider H3 rim (7.5 inch), over the stock Burb rim which is a 7 inch width?
And I don't have a clue if the offsets are different...
Just thought I'd see if someone has already done it..."Search" came up empty.
Thanks in advance.
