Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Caprice
Old 07-03-2009, 04:07 PM   #1
Connellt
Connellt Normal reputation
Freeze Plugs??
How hard is it to install freeze plugs on a '99 Chevy Caprice?
Connellt is offline   Reply With Quote
Old 07-03-2009, 04:31 PM   #2
inafogg
inafogg Normal reputation
Re: Freeze Plugs??
it depends on which plug is leaking.some can be a bitch,others are'nt too bad.what engine are we talking about??
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
inafogg is online now   Reply With Quote
Old 07-04-2009, 05:20 PM   #3
RageCage
RageCage Normal reputation
Re: Freeze Plugs??
Connellt,
FWIW, on my 85 with the 305 engine, I took a freeze plug out to drain the block. No big deal with the one I removed and replaced. Can't remember if there are any plugs in awkward spots.
rc
RageCage is offline   Reply With Quote
Old 07-05-2009, 01:15 AM   #4
silicon212
AF -Advisor
silicon212's Avatar
silicon212 Normal reputation
Send a message via ICQ to silicon212
Re: Freeze Plugs??
'99 or '89?
There was no official Caprice in North America from the end of 1996 forth. However, one could be had in the Middle East and it's actually a badge engineered Holden Commodore.
If it's an '89, pretty much the most difficult ones to get to are the ones at the back of the block. These require transmission removal.
On either side of the block there are two freeze plugs. One of these (the forward one) is underneath the engine mount bracket, so you will have to remove this in order to remove the freeze plug. There are also two freeze plugs on the front of the engine block, one under each cylinder head, outboard of the water pump. These are perhaps the easiest ones to get to, although you will have to remove the engine accessories to get to them.
On the passenger side, it will be necessary to remove the starter to get to the aft side freeze plug. ON the driver side, it might be necessary to remove the exhaust manifold.
Plan on a whole day if you've never done this before.
Also, the temptation might be great to leave the old plugs in the block instead of remove them - don't be seduced by the dark side! Use Channellocks and ViseGrips to remove them from the block. When you beat the old plugs inward to remove them, don't beat too hard or you might damage the engine. Be extremely careful here. The cylinder bores for #5 and #6 only allow enough clearance to barely clear the plug into the block - if you hammer hard, you might just hammer through the cylinder wall!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
PC Club is dead. Long live PC Club!
silicon212 is online now   Reply With Quote
Bookmarks
Tags
caprice, chevy, freeze, plugs
Google
Web AF
