2000 Taurus Fuel Pump wrong Guage Readings
I replaced a fuel pump with CARTER brand replacement from Pep Boys.
The gas guage is reading 3/4 when the car is full.
I returned the part as defective and got the same model for a Flex fuel extened tank model 2000 Ford Taurus.
Same problem.....Vin # tells us the specs of what pump to get....I did it twice...paying mechanics to change the pump (Labor)
Does anybody have any info on CARTER parts carried by Pep Boys or is there a calibrating process we are missing when you change a fuel pump.
Car runs fine otherwise....Could the sending unit to the guage been damaged on the first install....I don't see how...They disconnected the battery power, unplugged, dropped the tank, reinstalled....Everything is fine except gas guage reradout.
Is it part or mechanic? Same part twice...same problem with both replacement parts.
Can anybody help. Or tell me a right way to do this job with so many aftermarket manufacturers. Thankls
